0 members (),
118
Mod | | | Forums66 Topics128,186 Posts1,057,320 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68655 11/15/2006 2:06 PM | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I just bought a 6400 2 ton with a 261. I would like to put the 261 into my 1 ton stake truck. My question is; will the 6400 radiator and engine bolt up to my 4 speed trans? Or do I just move the engine over? I'd like to use the bigger radiator if I could but am unsure if the bigger truck stuff would fit in the smaller sheet metal of the 1 ton. | | |
#68656 11/16/2006 7:07 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The 1 ton radiator should be able to handle the 261 without problems. The 261 flywheel and bellhousing interface is the same as the 235.
#68657 11/16/2006 10:51 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What year truck is the 261? Is your 235 in the 1955-1st the original 6v engine/flywheel? | | |
#68658 11/16/2006 10:56 PM | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Both the 1 ton and the 2 ton are 1954 models. I assume everything is original. I know the 2 ton is original and unmolested with a bunch of factory accessories. The 1 ton actually has a 1950 216 in it. I'm unsure if the transmission has also been changed. I need to get a putty knife and dig for some numbers to find out. | | |
#68659 11/17/2006 3:26 AM | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 |
cgresham1212 If you don't drive it, why have it? 55 1st Series 3100 5 window
#68660 11/19/2006 9:34 PM | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | I tranplanted a 261 in my 51 half ton. The 261 I got was from a later 12 Volt heavy truck (2 ton?). I wanted to keep the stomp starter so I used the flywheel, clutch disc, and pressure plate from a 235 I got from another 1.5 ton truck (6 volt). The 12 Volt starter ring gear has more teeth and will not work correctly with a 6 volt stomp starter. I run the 6 volt starter on 12 volts and have had NO problems with it, but my pickup starts in about 1 one revolution.
I used the bell housing from the 235 I originally pulled out of the 51 after having it bored to fit the 89MM tranny input bearing housing. I also installed a radiator from a 50 Chevy 1.5 ton truck since it has one more row in the radiator (3 rows instead of 2 in the half ton radiator). Chevy trucks were not noted for having heating problems and I can run down the road 70+ mph all day in the summer (100 degrees+) and the temp gauge never gets above 180. Even around town with little air flow across the radiator it never seems to get hotter than 180.
Everything I did with the exception of boring the bell housing for a modern transmission was a bolt-in swap. | | |
#68661 11/20/2006 7:08 PM | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Thanks Racecarl, it's good to know its not that big of a deal. I'm fortunate I will be transplanting a 1954 261 into a 1954. This should make life fairly easy. | | |
