2 members (Ole49GMC, Hush), 74 guests, and 3 robots.
Topics128,169
Posts1,057,102
Members48,463
Just wondering if installing a 1970 6 cylinder motor out of a Nova would be compatible with the original bellhousing and tranny from a 57 Task Force 1/2 ton. Wondering about the mounting points also. If so, do you guys think flywheel would be the same as well ? Frank.
What engine does your 57 have in it now? If a V8 then yes you can mount that bellhousing to a 70 250, but if the 57 has a 235 6-cyl then it will not...
There is a good tech tip on this site about the late-6 bellhousings here . The 55.2 and later trucks are better candidates for a 230-250-292 swap than the prior years. The flywheels are different too. Good luck!!
Professional Novice
forgot to mention, it currently has a 235 6 cylinder. Thanks for the info Frank ! Frank.
