7 members (Rusty Rod, TUTS 59, Phak1, Napco Man, Cosmo, ndkid275, 1 invisible), 52 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#684601 10/09/2010 10:25 PM
Hey guys,
All of you with the 235 in your truck...where do you get your oil filters from? What's a part number I could use to try to track one down? Napa has one on order for me that they THINK might be right...has them baffled too. The filter out of my truck is about 5 inches tall (cartridge type), is an old AC Delco, and the number on it is P115...which didn't mean alot to the Napa guys.
Truck is a 61.
Adam61 #684610 10/09/2010 11:21 PM
Try fram c4
and fram cp4
The orielly web site gives the dimensions, you can compare with your housing.
I used the cp4 and ordered it from autozone. It was for an earlier 235 with a remote housing on the manifold.
http://www.oreillyauto.com/site/c/s...Chevrolet&model=Truck&vi=1326473
Good luck
Look at the dimensions of one of the filters that match C21 on NAPA. C21 & C21P will mean something to NAPA workers.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=151860#Post151860
Dads50, my truck has the oil filter in a canister, which is mounted to a bracket that's connected to the intake manifold. Is this what you meant by "remote housing"?
Here a pic of the one I have on my 50
oil canister pic
I just changed my oil tonight, new filter also. my local Orileys has the filter for my truck in stock.
Mine's kinda like that but not quite. My engine itself doesn't look much like yours at all. Pretty sure it's original to the truck but not entirely sure...will have to find out.
The Blue Funk uses a NAPA filter #1530. I think it's height is about 8".
The Blue Funk's oil canister is bolted onto a bracket over the left wheel well. In my finite experience, I've not seen another like it. Most are bolted onto the intake manifold.
Dave
The Blue Funk: a '51 3100 4 OTF with a '57 235
More pix on Photobucket
Purolator L30034 was correct for mine and should be the one you need.
You Tube
Curt B. #684843 10/10/2010 10:26 PM
Thanks you guys. Yeah, my canister is connected to the manifold and is 5 inches tall. Should be able to track it down eventually.
Dealers like Jim Carter and ClassicParts carry them too.
Drew
DrewP #684929 10/11/2010 3:27 AM
A NAPA 1100 filter fits mine
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
DrewP #687113 10/18/2010 4:36 AM
I used a wix 1100 from O'Rileys for my 235 remote mount oil canister filter
smile
Brad
