0 members (),
68
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | I have a deep cycle battery that went a little on the dead side, No it's not out of my truck. Charging that battery seems different and was wondering if there's a different or special way to charge one up. I had another thought as I was looking at the charger, which I have on at a 6 amp rate which puts the needle in the grn. zone.....Why can't you use one of these in vehicle ?
Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Sounds to me like your charger is working just fine on the deep cycle battery. It's probably going to take more time to reach full charge than you're used to but I think if you're patient, it will get the job done.
I'm not an expert on deep cycle (RV) batteries but I think the problem with using one in a vehicle would be the lack of CCA or cold cranking amps. An RV battery is designed for steady and slow discharge. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Deep cycle batteries I've had experience with aren't made to handle large amperage loads like they would get when starting a vehicle. They're made to provide extended amp loads with the ability to be deeply discharged & recharged without being destroyed.
| | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | | | |
