3 members (cmayna, tclederman, 1 invisible), 121 guests, and 1 robot.
Topics128,134
Posts1,056,402
Members48,441
Hi Guys,
searched the site and I canna find..... ohwell
Looking for the placement of the hole for the antenna....bought a repro and the instructions are vauge as He**. (3 different hole locations...) :mad:
I have the hole size needed but I don't want to screw it up (measure twice cut once!) eek
Unfortunately the newer fender has no hole!
GMC: Get More Cash...
1958 GMC
My Webshots photos
don't have the template, but the accessory instruction might help [see 2nd page, view 5], and this is it installed
Thanks!
1958 GMC
My Webshots photos
Does anyone have that template? I also purchased the aftermarket and you are right. Those instructions are useless. I took those instructions and tried to match them up on a fender that already had a hole for the antenna. It didn't line up either. None of the references make sense. I'm not sure the fender with the hole is right. Someone could have drilled it themselves. I'd hate to drill the hole in a good fender only to find out it's wrong.
Brian
Moderated by  truckernix
