| | | Forums66 Topics128,152 Posts1,057,011 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68435 11/11/2006 12:29 AM | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | I just pulled my engine and need to change my oil pan gasket. I have my engine on a stand. I drained the oil but I can still here water in the water jackets and what not. If I turn the moter completley over on the stand is ther any chance of water getting in it????
Roger http://www.flickr.com/photos/45469713@N00/?saved=1
#68436 11/11/2006 1:21 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | rogpatt,
I don't think so. The cooling system is pressurized...separate from the engine internals and such. Turning it over on the stand won't change the integrity of the cooling system.
You might get water coming out of the engine onto the floor, but it won't get into the guts..they are still separate.
Stuart | | |
#68437 11/11/2006 10:37 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is a plug or petcock on the drivers side of the engine way to the rear lower part of the block on a 6. On an 8 there are 2 plugs one on each side. I like to pull the oil pan before I turn the engine over. That way the crud left in the pan doesn,t get bup in the engine. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
