7 members (Hanks custodian, TUTS 59, Guitplayer, Gdads51, Steelonsteel, Mike Burns, 1 invisible), 84 guests, and 3 robots.
Topics128,066
Posts1,055,871
Members48,428
#683887 10/07/2010 3:20 AM
since i can't "normalize" the engine to adjust valves prior to start-up, if i set the exhaust clearance at .020 and the intake at .013, would that give me enough lash to allow normalization and then reset clearances to factory specs?
still a few days away from actually starting the engine but i am planning on setting the valve clearance in the morning and wanted some input.
p.j. #683951 10/07/2010 12:15 PM
That's about what I did to get mine started then set them when it got hot.
Pete
For a cold setting I just increase the hot specifications by .002" and recheck after a warm-up and head bolt retorque. Even if it's a "no-retorque" head gasket, I just feel better doing a hot retorque.
Your best bet is to follow Jerry's advise. Your settings sound way to loose. My 40 shop manual says with "0" time running the engine and the oil and water temp at "70" the intake should be set at .006 and the exhaust set at .013. Don
