2 members (J Lucas, pauld), 123 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
I've been scouring the web for the plank sizes of the 7 boards that make up a 46 1/2 ton shortbed.
I've found that they are either 77 1/8" long or 76 3/4" long. Which is correct?
Are they supposed to be 5/8" thick or 3/4" thick?
How wide is each board?
How deep and wide is the groove along the edge for the bed strips?
I've purchased a Mar-K box kit but did not think it was worth it for the wood as we have plenty of it up here in Canada. I figure I'd make my own but I do not know the exact measurements. Any assistance is always appreciated!
If you have the short bed, the wood is 77" long. Long bed uses 87" & 97" wood.
You must seal all sides to insure against warping and bowing from moisture. Use a marine spar varnish and cover all sides. Any uncovered areas will allow moisture in and cause the wood to warp.
Harold
Actually, I think Mar-K site has bed wood dimensions / info., including edge profile for bed strips.
1940 Chevy KC 1/2-Ton
