| | | Forums66 Topics128,187 Posts1,057,212 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 210 Shop Shark | | Shop Shark Joined: May 2008 Posts: 210 | I've been scouring the web for the plank sizes of the 7 boards that make up a 46 1/2 ton shortbed.
I've found that they are either 77 1/8" long or 76 3/4" long. Which is correct?
Are they supposed to be 5/8" thick or 3/4" thick?
How wide is each board?
How deep and wide is the groove along the edge for the bed strips?
I've purchased a Mar-K box kit but did not think it was worth it for the wood as we have plenty of it up here in Canada. I figure I'd make my own but I do not know the exact measurements. Any assistance is always appreciated! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | If you have the short bed, the wood is 77" long. Long bed uses 87" & 97" wood. You must seal all sides to insure against warping and bowing from moisture. Use a marine spar varnish and cover all sides. Any uncovered areas will allow moisture in and cause the wood to warp.
Harold Is a restoration ever finished? | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Actually, I think Mar-K site has bed wood dimensions / info., including edge profile for bed strips. | | |
