0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68349 11/08/2006 5:47 PM | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | I'm trying to ID the rear end that came with my truck. I know it's a later model GM product but I want to make it easier to buy the parts I need. It's a 10 bolt, enclosed driveshaft unit with Bendix brakes. I'm pretty sure it's early 50's vintage.
There are two elongated indentations on either side of the front of the axle shaft about 12" in from the backing plates. Does anyone know what these are for?
Can anyone tell me whether this rear end will mount right up to my truck and work properly? When I bought the truck, the PO had disconnected the lever action shocks and tried to mount gas shocks to it. It was cobbled up a bit. I just need to know how to mount this thing up, since I don't have the original rear end. It's all I've got to work with at this point.
I know this is a lot of information and I really appreciate anyone's input.
Neil 1940 GMC 1/2 Ton
#68350 11/08/2006 9:19 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I have a complete rearend out of a 40 auto I could make you a real good deal on if you were close enough to pick it up. Oregon to Kansas would be a heck of a drive. It'd probably cost a ton to ship it. I don't know if it would be a direct bolt up or not. If you're interested let me know. I just want to get it out of the way.
#68351 11/08/2006 11:32 PM | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Yeah, that's pretty far Tiny. I'm tempted, but I think I'll pass. Thanks for the offer, though!
#68352 11/09/2006 6:44 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Neil, Is your 1940 a long or short bed? If I understand correctly, You have another torque tube rear end, and you want to know if it will work.
I know S. F. is a bit of a drive too, but I will be getting rid of my 1940 3/4 ton gmc rear soon. I believe this to have the 4.56 ratio, but have not confirmed. It is 6 lug, just like the 1/2 tons. | | |
#68353 11/10/2006 6:48 AM | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Hey Bigbadswingdaddy, That sounds like it might be a plan. My truck is a long bed. I'm not sure when I'll be back down there but I do get down that way fairly regularly. Is it something you can hang onto for a bit or do you want to get rid of it asap? We're actually moving back down there mid next year. I don't expect you to hang onto it that long, but I'd like to get together and compare notes. Let me know.
#68354 11/10/2006 9:12 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Neil, I am at least 3 weeks away from the rear end swap. I am waiting for some critical components and looking for a suitable location to do my work. I will not be able to hold onto the spares for long, but do want to find the spares a good home. I have both a 3 speed and 4 speed transmission. I can take any necessary measurement.
John | | |
