| | | Forums66 Topics128,035 Posts1,055,445 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 9 New Guy | | New Guy Joined: Apr 2010 Posts: 9 | How can I tell if the fuel pump doesn't work? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If it's off the truck, pump the lever by hand with fingers over both holes. If one sucks & one blows it's most likely good. If it's on the truck pull the line from the carb & crank then engine. If you get gas it's most likely good. Of course there are exceptions to the rule but most times those will tell you what you need to know.
