| | | Forums66 Topics128,010 Posts1,055,308 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 8 New Guy | | New Guy Joined: Jul 2010 Posts: 8 | Hey all, I have a 61 C20 with a flat bed on it. I'm pretty sure it was originally a 6' fleet side, but I like the looks of the step sides better. Will the frame accept either or? Thanks | | | | | Joined: Jan 2010 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 52 | Hello Jake. If your truck is indeed a C20 then the 6 1/2 ft. bed wasn't an option. It should have a 8 ft. bed with a wheel base [center of front hub to center of rear hub] of 127 in. Short beds were 115 in. Those are 1963 specs and I don't think they changed much between years. If your truck appears shorter then maybe the frame was swapped or shortened. Do you have 6 lugs or 8 lugs?
| | | | | Joined: Jul 2010 Posts: 8 New Guy | | New Guy Joined: Jul 2010 Posts: 8 | It is an 8 lug. But here's the thing. This is a crew cab conversion. I don't have a measurement of the wheel base, but I'll get one. | | | | | Joined: Jan 2010 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 52 | Crew Cab, that explains it. Your'e looking at a short step bed which is 82-1/8 in. in length. It will fit right in if you have 42 in. between the back of the cab and the center of the rear hub. I doubt that you will though. You will have to do some fitting. In the Gallery is a photo of a 64 crew cab with a step bed on it. Look for Rich Sisnero's 64 crew cab. You will see the bed had been shortened considerably. | | | | | Joined: Jul 2010 Posts: 8 New Guy | | New Guy Joined: Jul 2010 Posts: 8 | Thanks! I have exactly 42" from the back of the cab to the center of the hub. | | |
