2 members (37 GC, Shade Baby),
125
Mod | | | Forums66 Topics128,141 Posts1,056,779 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 11 New Guy | | New Guy Joined: Apr 2009 Posts: 11 | I seen a post on here a while back but can not find it on where to cut the frame on a 3/4 ton frame to make it a short bed.Can anybody give any help on this.Thanks. | | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | just get a 1/2 frame, they can be found for very cheap. | | | | | Joined: Apr 2009 Posts: 11 New Guy | | New Guy Joined: Apr 2009 Posts: 11 | I have a 3/4 ton frame thats been completed but would like to shorten it now. | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I would be sure to cut out a section where there is enough length of the same dimension channel. That way you can butt the two pieces back together and weld them, then put a plate on the inside and completely weld it too. I wouldn't even be opposed to a plate welded on the outside either. If you're not sure about your welding skills, get someone else to do it. This isn't a place to skimp or let macho pride get in the way!
In short, measure twice and cut once. Good luck!
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
| | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | Where ever you decide to cut the frame be sure and cut it at a 45 degree angle. cut the section to be welded together at a 45 degree angle, grind the ends of the 2 sections to a V, put them together and then full weld the 2 pieces back together (inside and out). after cleaning the welds and grinding , then add a section of plate on the inside of the frame with the ends being shaped like a V. Full Weld on the inside of the frame taper the edges of the strap for better width weld. The first question every one asks is why on a 45 degree angle ? The answer is the stress never gets a straight shot at the weld, the stress is spread out so the weld does not fail. Remember when you heat the frame you weaken it, This technique insures that the rejoined section of the frame is stronger than it was before it was modified. Kieth
66 GMC SWB 65 Chevy LWB 65 GMC SWB
918-446-2245
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | "TRUCKS!" featured a '65 or so longbed which they cut down to a shortbed. They did not use the 45 degree concept. They "Z"'d the frame The area behind the cab and in front of the rear axle. You can see it here if you missed it on TV. http://www.powerblocktv.com/magazine/?pub=2ae59aac&page=30 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What year truck are you working with? This can make a huge difference as to how to go bout shortening it, especially if it is a '47-'54 Advance Design truck (tapered frame). Personally, I agree with Garandboy, shortbed frames are very common, no need to ruin a perfectly good and much less common longbed.
Bill Burmeister | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Apr 2009 Posts: 11 New Guy | | New Guy Joined: Apr 2009 Posts: 11 | Its a 52.Was planning on cutting out 9 inches behind the cab or in the area of that.Thought I had seen a post of one being done this way posted a while back on here.Thanks for the info. | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | Check my pictures ,hope they will help.Frame is Z cut because the front section is not tapered like the rear .When the two are joined the frame fits ! Watch where you use that straight lazy cut !
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | 9", why bother? Leave it as it is and you have a tad more room in an already small bed. Turning radius is good to start with, so no worries about the slightly longer wheelbase, you won't gain all that much by shortening.
What's the "reason" you want to shorten the frame?
Grigg | | | | | Joined: Nov 2000 Posts: 1,971 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,971 | Well 9" is the difference in wheelbase of the 1/2-ton and the 3/4-ton (9-1/4" actually). He can put a 1/2-ton bed on it... and some like that short-truck look better... ?? Anyway, it's his truck to do what he wants.
Why do you want to do it?
Professional Novice
| | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | TooMany2count Pictures were taken with my phone .Lesson learned only use the camera .Computer ,phone and photobucket don't get along .The pictures will still show how to cut the frame . | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Whether you shorten it or not you're getting unnecessary advice on welding one of THESE frames. The frame under your truck is made from mild steel. It is nothing more and nothing less so as long as your weld is done correctly, complete penetration, no undercutting, etc., you can cut it square, run your weld and be done with it.
Take it from someone who TIG welded for 4 years on automotive parts (including shortening and lengthening frames) and 6 years on jet engine parts for Eastern Airlines, a properly executed weld is actually stronger that the parent metal so as long as it's done right, there is no need for angle or Z cuts nor is there any reason for additional plates. Your greatest concern is that you make your cuts precise and line things up properly.
On the other hand, welding exotic steel alloys and/or heat treated metals is an entirely different story. | | | | | Joined: Oct 2007 Posts: 91 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 91 | My 52 dump truck was lengthened 24 inches using 45 degree cuts with no gussets or plateing. After 58 years there is no signs of bending or cracking.So I would agree with Czechman. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | My 48 2 ton frame had clearly stenciled on the inside something to the effect of "don't cut or weld on frame" You'll find similar notes on most all if not every big truck frame today.
The old frames may not have been as special a steel as we use today for truck frames, but that is not an excuse to do a less than professional job. Hire a professional if necessary, someone that not only can, but actually knows how to properly repair truck frames.
Still curious about the original post, what's the reason you want a shorter frame?
Grigg | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | My 48 2 ton frame had clearly stenciled on the inside something to the effect of "don't cut or weld on frame" You'll find similar notes on most all if not every big truck frame today. Grigg If you look at what some people call welding I don't blame them one bit for that warning. It's also possible that frames for heavier trucks are heat treated but such is not the case with a 1/2 or 3/4 ton frame. | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | | | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | I have been in the used class 8 truck business for 25 years, build dump trucks and have stretched, shortened, or double framed hundreds of big trucks and this is how we shorten them. I did not see the tv show. I will take a look though. I have a complete 65 LWB frame that I am pulling out of a 65 chevy. I was able to find 2 swb frame in 2 days so I did not have to shorten it. Kieth "TRUCKS!" featured a '65 or so longbed which they cut down to a shortbed. They did not use the 45 degree concept. They "Z"'d the frame The area behind the cab and in front of the rear axle. You can see it here if you missed it on TV. http://www.powerblocktv.com/magazine/?pub=2ae59aac&page=30
918-446-2245
