5 members (Pre '68 Dave, 3B, Robert Crandall, treegrower, kades51), 114 guests, and 2 robots.
Topics128,134
Posts1,056,737
Members48,454
I am having a difficult time trying to find what the rear end I have under my AD truck is out of. I will tell you what I do know. I have the following numbers off the rear end: GM 24, K116, 389486 (with letter N above it), on the tube it says HI 05 25 W. I have tried searching for these numbers in the codes but have had no luck. I have jacked up the rear end to spin the tires. They spin opposite directions so I have an open differential. Any help is greatly appreciated!
A photo of the rear cover would help a lot.
I went to the chevy dealer parts dpartment, they have access to all the info you need, I was in the same boat and wanted to verify what the seller told me after I bought my rear,, they were more than willing to help..I will look for the printout they gave me but I kinda think I chucked it, good luck hope this helps...
Here is a picture of the rear end.
http://tinypic.com/r/314avjn/7
The only thing I can find with a "N" by the casting number comes on a Chevelle rear end. I am going to double check the "HI" to see if it might be a "KI". If anyone else has any other ideas please let me know what I can try. Thanks!
It definately says "HI" 05 25 W. Here are some pictures of all the numbers I have.
http://tinypic.com/r/2jfyght/7
http://tinypic.com/r/j5vzft/7
http://tinypic.com/r/2en5gl5/7
If you google 'gm rear axle identification' you'll get a number of links to drawings of rear covers and what rear they are from.
It looks to me like a 7.5 from an S-10 but I may be missing something.
I looked at a lot of these links. The picture of the rear end I have has the "eyebrow" shape which every link says it's a 8.2 10 bolt. I did some checking and found out that a chevy G10 van has the HI code, now I am trying to research if these vans came with an 8.2 10 bolt rear end in 1966. (1966 is what the K116 number tells me)
I went back and rechecked the links I initially looked at and none of them showed the eyebrow. However I checked a few more and did find the eyebrow as an 8.2.
I think you have your answer.
