7 members (Gdads51, Otto Skorzeny, Wally / Montana, LuckyLee, MickeyP, TUTS 59, kades51), 72 guests, and 1 robot.
Topics128,051
Posts1,055,705
#683089 10/04/2010 4:15 PM
Currently I have the original 6volt starter on my 54 235 engine but looking at switching to a 12 volt system and would love to keep the original starter just like the concept of how it all works. Just wondering if the 6 volt starter could be reworked to take 12 volts.
Randy
Yes it can. However, 6V starters have been known to work for years as is on a 12V system.
My 6v starter has been spinning on 12v since late '70s.
thanks guys
wasn't sure if the windings would hold up to the extra voltage
makes my decision lots easier of going to 12volts for sure
One thing to do is keep the engine well-tuned so it starts without extended periods of cranking. If the battery ever gets low enough that the cranking speed drops, the starter will begin to draw massive amounts of current and damage the circuits inside it, so never keep grinding on a starter until it won't turn any more, or turns very slowly. A properly-tuned stovebolt engine with 12 volts against a 6V starter should start within 2-3 seconds of starter operation every time. The starter will last for many years under those circumstances.
Riding in the Passing Lane
A 6 volt starter will last longer on 12 volts then on 6.
1972 Chevy c10 Cheyenne Super
