4 members (jmoore, DaveV, KEVINSKI, Youngin' Tut 59), 129 guests, and 3 robots.
Topics128,127
Posts1,056,681
Members48,452
#682850 10/03/2010 3:40 PM
listing in paper for a 66 chevy with auto towing drive shaft, what does the term refer to.
Redryder pix
My Hotrod
I'd ask the seller.
Probably auto trans driveshaft with beefed up u-joints for towing. But yes, ask the seller only if you need a driveline.
There is a special driveshaft available for cars that are flat-towed behind motorhomes, etc. that can be disconnected to keep the transmission and driveline from turning. It's a sliding coupling similar to a synchronizer that disconnects the rear u-joint to prevent spinning the driveline. Never heard of it being used on a full-sized car, but I guess it's possible.
joker,I did a google search and came up with this link.
drive shaft
Tim
1951 3100 Chevrolet
