| | | Forums66 Topics128,078 Posts1,056,039 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 32 | In the process of rebuilding a 3 speed column,bearings,turn signal switch, for a 1963 c 10. Starting to reassemble and have a spacer that I'm unsure of where it goes exactly.I think it either goes in between the bottom shift lever and the spacer in between the shift levers, or, in between the bottom shift lever and the round piece that holds the bottom bearing. If any one knows or have an exploded view of the column to share would be a great help. | | | | | Joined: Dec 2008 Posts: 40 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 40 | Here's an exploded view of a 1966 column, not sure if they are the same. I also have lots of pictures of my column if the diagram isn't helpful.
http://webhosting.web.com/imagelib/sitebuilder/misc/show_image.html?linkedwidth=actual&linkpath=http://www.64moneypit.pages.qpg.com/sitebuildercontent/sitebuilderpictures/diagrams/61col3.jpg&target=tlx_pic3mv4
Trey Wilkins -------- 1950 Chevrolet 3100 Five Window1954 Chevrolet 4100 Dumptruck (Sold)1957 Chevrolet 6400 Dumptruck1966 Chevrolet K20 Longbed Fleetside1966 Chevrolet C60 Grain Truck (Sold)In the Stovebolt GalleryMore pix on Photobucket | | | | | Joined: Mar 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 32 | Couldn't get into the site to view.Can you help me out? | | | | | Joined: Mar 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 32 | Maybe you can email the pictures to me. My address is [email protected] | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | | | | | | Joined: Mar 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 32 | Thanks, will study it. Should do the trick. | | |
