0 members (),
89
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | I have a ’53 3600 with the original rear end. On the top of the rear axle housing on the driver side, there is a small tube with a loose fitting top that I take to be a breather tube and cap (the cap appears to be simply crimped on to the tube but spins). Recently the rear end seemed to be leaking (never before) so I changed the gear oil in the rear end up to the fill plug on the back of the housing. After some driving, I see that it is dripping a little gear oil again. I wiped the casing with dry paper towels and have determined that it is coming from the “breather cap”. Should this breather have some felt or other suitable packing inside to allow for air to escape and enter but prevent the oil from “blowing out”? There appears to be nothing under the cap as it turns freely and is loose. There is nothing that I can find in the shop manual that mentions this. John
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I have pulled a few of these and never seen any packing in them. If it continues there are several improved "street rod" applications that have check valves to prevent the spilling of fluid. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You are right it is a breather. If the cap is loose the breather is generally not stopped up & the fact that oil comes out is another factor that it is not pluged up. Oil should not come out of it though. You may be getting it too full or it is not the proper grease & is foaming. Sometimes the cover gets put on upside down causing the fill level hole to be up way too high. The level of the grease should be about even with the lower part of the axle tubes. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 56 | Even new Gm trucks specify to fill the rear axle about full to the hole or about 3/4" low. | | |
