| | | Forums66 Topics128,153 Posts1,056,842 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | If you hook DC to a coil of copper wire you get an electro magnet.
What if you hook AC to the same coil?
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes to the DC,simple experiment, 16d nailwrapped with wire and connected to a 'D' bat. And you get a choke with AC. DG
Denny G Sandwich, IL
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | My dad had an AC coil on his work bench he used to magnetize and de-magnetize screw drivers.
Denny, when I was a youth I built a primitive buzzer using a nail and wire. | | |
