5 members (Otto Skorzeny, Woodcmiami, 3B, 55shaker, Wally / Montana), 216 guests, and 1 robot.
Topics128,086
Posts1,056,098
Members48,434
#682718 10/03/2010 12:54 AM
dwm
Offline
In the process of rebuilding a 3 on the tree column and had to set a side due to personal issues Now going back at it and there is a spring washer that I believe goes either inbetween the shifting ear and spacer between the ears or against the bearing housing and the shifting ear. Cuuld someone out there help me out?
maybe some pictures would help, your description leaves a lot to the imagination - what year truck? are you rebuilding the column or the shifter? how is a '3 on the tree column' different from a '4 on the floor column'? what is a 'spring washer'? what are shifting ears? which bearing "housing" is near one of them? are you talking about the shifter box?
dwm
Offline
It's a 1964 c10. Put new bearings on both ends along with turn signal switch. The 3 speed column has the "ears" that the shifting linkage attaches to at the bottom of the column. The washer is round but has a wavy shape to it. And finally the housing is the piece that the lower bearing is pressed into that the steering shaft goes through.
1 Offline
squeeze you have documented some really helpful info. dwm i rebuilt one of those columns 27 years ago just to get a original 64' c-10 out of the guys garage with all new factory parts he had purchased and it was no fun as i think after the 3rd time i drove the truck down the road, made a call to a buddy asking him to bring his trailer because 1st gear was all i could get. the truck only had 50k on it when it was parked because of linkage problems and the guy wouldn't sell it unless i drove it away. you need to find exploded view or somebody that has done more than i rebuild. good luck.
dwm
Offline
Thanks for the advice. Is there anyone out there with access to an exploded view they could share with me, could there be one in a shop manual?
aaahh - year does make the difference ... the wavey washer is a spacer, the ears are the shift levers, the housing is a mast jacket - the 60-66 factory assembly manual may have some breakdowns, the shop manual should have some info on adjustment and may have external column pics that could help ... might easier find someone with good info in the 60's forum
dwm
Offline
Ok. Will try there. Thanks
