3 members (klhansen, TUTS 59, 1 invisible),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,192 Posts1,057,355 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 63 | Hey Guys,
been awhile and have been busy raising a family. I want to be able to take my family with me for drives in the truck but want everyone to have seat belts. So to all who have installed some. What have you done? I'm looking for any info on what to use, and how/where to install them too in order to be considered somewhat "safe" Any help would be great!
on yeah, the truck is a 1960 C10
Thanks,as always -Danny
1960 C-10 Stepside,Longbox 235,4spd 3.90 diff.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 3 point belts from around 1985 Chevy truck will work. They have a "boot" that holds the mechanism and looks good and is thin. This boot is mounted to the floor with one bolt. When you find a donor truck, you want to get all the special bolts and nut plates, ALL of them, so you will have options. Not sure about a 1960 but here goes: slit the upper door post from rear or front, whatever is best and to be able to hide the slit with trim. Drill a hole where the upper sling ring will go best. Insert one of the nut plates (about 2" square, bigger the better) into the slit. Line up with the hole and attach the sling screw thru hole and into the plate. You may have to use wire/strap welded to the plate to hold it, then bust off with back and forth motion after screw is in, Shape/cut the plate so that it can not turn in the slit. Have it bang against structure inside the post when trying to turn. Bolt the boot to floor just back of the door opening and bolt the buckle clip webbing or stick up holder to floor behind seat in proper location. you will see how all this goes by observing the donor truck and taking pictures before removing from donor truck. Use original plates or grade 8 hardware with 3/16 or better thickness plates. Use best judgement according to what frame/crossmembers are found under your truck. One of the dangers of adding belts to non belt vehicles, engineering wise, is that the seat attachment strength may not be correct. Check to see if your seats are strong at attachment and elsewhere. If seats come loose and belts stay, serious injury will occur. Also some truck seats fold with no "catch" mechanism and some "catch" mechanisms are not strong enough to keep the back of seat from collapsing. This must also be addressed. As you can see, just slapping some belts in an old truck is not safe at all. Your attachment point at the pillar must me solid. A nut plate shaped like a diamond and as large as you can get into a slot will not pull thru the sheet metal and will not turn when tighening. I don't recommend welding anywhere during this process, except that bust off strap. There are lots of ways to hide the slot. Make a two screw access plate, etc. This is the best I can do using my experience on a TF truck and not knowing exactly the configuration if your truck body. But you can get the basic idea and expand and modify. This is just to get you thinking in the right direction. Of course you can do a two point belt system if you want, but all of the info is the same re: safety. Allot of the salvage yard belts have been cut by the fire dept to remove the occupant, so find a guy who is parting a truck. You can buy new stuff from many aftermarket vendors also. Bartamos
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Here's how I did it on a '56 wide window. It may give you some ideas. | | | | | Joined: Sep 2010 Posts: 24 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 24 | I used bucket seats from a 03 chevy truck. They have the seat belts made into the seats. Im not staying orignial so its not an issue for me. The center portion of the 3 pc seat I had to modify the bracket and it also had the seat belt made into it. I like them alot more than the original bench seat. | | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | If you have to have seat belts to take the family out in the truck, it seems like no seatbelt = quiet time! | | |
