3 members (Hotrod Lincoln, 2-Ton, 1 invisible),
63
Mod | | | Forums66 Topics128,021 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | the head casting #3835913 -in liners says 1954 & 55 Chevrolet 235 Will this head work on a 1959 Chevrolet pickup truck motor 235- casting # CON G39? Thanks Bill | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | 56 to 62 takes a casting #3836848. The head gasket is the same, but there is a difference in the water ports. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The head will work fine, the only problem you will have is the temp sender hole. 1956 and later had electric senders that require a larger hole in the head.
See the USA in your vintage Chevrolet! My Blog | | |
