Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Peggy M, Shof, 55shaker), 163 guests, and 2 robots.
Topics128,281
Posts1,058,488
Members48,490
#673759 08/28/2010 9:46 PM
PC
Offline
My truck (1952 6400 2 ton) has the hydrovac unit.
Does anyone know if a power assist brake unit can be used to replace the hydrovac?
PC
PC #674117 08/30/2010 2:05 PM
yes
•1952 Chevrolet 3800 pickup
---All pictures---
PC #674174 08/30/2010 6:54 PM
What is the power assistbrake unit
bbolts #674180 08/30/2010 7:37 PM
Traditionally they are vacuum boosters bolted to a master cylinder, like most newer cars and pickups have.
Alternatively you can use a hydrobooster as found on most if not all current diesel pickups. If you will have power steering this is my preferred choice by far. A hydrobooster uses PS pump pressure to help instead of vacuum, it is attached to the MC in a similar fashion as a vacuum booster.
An older solution is the hydrovac like you have, and some slightly newer versions of the same thing could be substituted.
Grigg
---All pictures---
Grigg #682415 10/01/2010 9:16 PM
I have a 52 6400 and I put a on the firewall split system. The vac booster/master set up was $200 at NAPA and went to a chevy 1-1/2 ton, 1997 I think. Part No# 54-71046.Used the pedal from a S-10 and built the support for it. My rear wheel cylinders were good so I just put on new front ones. I had just cleaned the seat with WD-40 and went to try them. I was slammed into the steering wheel with great force. This is now a split system so if one brake line goes bad you still have brakes. Bob
I'd much rather have a full bottle in front of me, than a full frontal lobotomy!!!
And I am building a truck.
http://s989.photobucket.com/albums/...w&track=share_email_album_view_click
