2 members (Shaffer's1950, 1 invisible), 36 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#681091 09/27/2010 8:38 PM
i am wanting to covert a 47-54 truck to 4wd. has anybody done this and what is the easiest way about doing this. Such as frames....
ben1234 #681147 09/28/2010 12:22 AM
It's been done. If you try a few searches you will come up with some examples here.
Without a better idea what your purpose is in converting the truck its hard to give a specific answer.
OldSub #681350 09/28/2010 2:47 PM
I didn't know if it is easier to put the axles under the stock frame. or use a blazer frame a s-10 frame or even a tahoe frame.
ben1234 #681356 09/28/2010 3:20 PM
ASK napco man his name is george he is on this site he the is the resident expert.
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
apart hillbilly #681622 09/29/2010 8:13 AM
I am in the process of converting my '50 to four wheel drive. I chose to sling a front drive axle under mine. In the process, I gained about 8" of alititude! A little too much for my needs, but I'm kind of stuck with it now. If I had to do it over again, I think I would put the body on a 4x4 chassis, and avoid the "engineering night mares".
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
chevoldsmoyota #682364 10/01/2010 6:02 PM
Here are two forums to explore:
http://napcopowrpak.groupee.net/groupee/forums?s=5271003771
http://napco4x4.org/forum/
Good luck finding the running gear!
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
enigmaT120 #682761 10/03/2010 3:09 AM
I wanted to convert my to 4WD. The best way is a frame swap which presents problems of its own.
Then I remembered. These trucks go just about anywhere, even in the snow. If you actually need 4WD, do you really want to go there with your truck????
I plan on using BF Goodrich Commercial T/A Traction tires. They are mud and sno rated with the mountain snowflake symbol which means severe weather use. They will look awesome and last a long time. Not the cheapest though. MADE IN USA!
52Dave3600 #683388 10/05/2010 2:50 PM
Why not switch to a posi rear and chains? Trust me, you can go where ya need to without all that parasitic weight. Much easier to engineer too.
dg
