2 members (Bill Hanlon, 1 invisible),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | http://img832.imageshack.us/i/mysteryparts.jpg/Almost done with the truck and I have these parts leftover. I have no idea what they are or where they go  It's sheetmetal, if you can't tell, and each one is maybe 8 inches wide. One has a little sharper angle bend across the top than the other. They look like some kind of trim pieces or something but I can't figure it out. Any ideas?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy chicklin, firstly you only use one of those per truck, that is the upper flywheel shield from a six cylinder engine, hope that helps. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I'd say they're part of the bottom cover of the bellhousing - well, one of them is, the other goes into the stash for a future project  the top one looks bent at the bottom of the curve Bill | | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | Are there more than one kind? The angle of the bend across the top is different on each one?
I think my engine already has a cover, too. These go on the upper half of the bellhousing on the engine side?
The previous owner put a '55 235 out of a car in the truck. I had an extra flywheel cover, too, that didn't fit.
| | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | Ah, it just occurred to me that I remember being able to see the flywheel from the rear (tranny side) of the bellhousing, down low. Is that where is goes? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | exactly - of the 2 different shapes, one will fit better, but maybe neither is the correct one - the "top shape" is actually the bottom, mateing to the lower bellhouse pan, the large cutout faces upward
| | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | | | |
