1 members (baldeagle), 69 guests, and 4 robots.
Topics128,037
Posts1,055,467
Members48,424
#681852 09/30/2010 2:31 AM
http://img832.imageshack.us/i/mysteryparts.jpg/
Almost done with the truck and I have these parts leftover. I have no idea what they are or where they go smile
It's sheetmetal, if you can't tell, and each one is maybe 8 inches wide. One has a little sharper angle bend across the top than the other. They look like some kind of trim pieces or something but I can't figure it out. Any ideas?
chicklin #681857 09/30/2010 2:36 AM
3B Offline
Hy chicklin, firstly you only use one of those per truck, that is the upper flywheel shield from a six cylinder engine, hope that helps.
chicklin #681858 09/30/2010 2:39 AM
I'd say they're part of the bottom cover of the bellhousing - well, one of them is, the other goes into the stash for a future project wink the top one looks bent at the bottom of the curve
squeeze #681867 09/30/2010 2:56 AM
Are there more than one kind? The angle of the bend across the top is different on each one?
I think my engine already has a cover, too. These go on the upper half of the bellhousing on the engine side?
The previous owner put a '55 235 out of a car in the truck. I had an extra flywheel cover, too, that didn't fit.
chicklin #681868 09/30/2010 3:00 AM
Ah, it just occurred to me that I remember being able to see the flywheel from the rear (tranny side) of the bellhousing, down low. Is that where is goes?
chicklin #681873 09/30/2010 3:05 AM
exactly - of the 2 different shapes, one will fit better, but maybe neither is the correct one -
the "top shape" is actually the bottom, mateing to the lower bellhouse pan, the large cutout faces upward
squeeze #681876 09/30/2010 3:09 AM
Awesome, thanks!
