5 members (klhansen, Mike B, Hotrod Lincoln, cmayna, Woodcmiami), 42 guests, and 2 robots.
Topics128,030
Posts1,055,421
Members48,422
#681452 09/28/2010 9:42 PM
Got a Chevrolet motor 235 I think? Year unknown? Motor is a transplant into a 1941 chevrolet ton & 1/2 dump truck.
Says Chevrolet on blue valve cover 2 screws on each side hold it on, oil cap on top of cover
head casting #3835913 driver side of head.
On the pass. side of head
B26 913
241
570
In liners list head casting #3835913 as 1954 1955, 235 head--original head I don't know?
Plate behind distributor F706J number.cannot find the distributor plate casting # listed? Cannot find block casting # anywhere on block ?
Need correct year of motor so I can buy parts.
thanks Bill
55 GMC #681519 09/29/2010 1:06 AM
The serial number comes out as Flint plant, built on June 7th, and the original application was truck w/manual trans, weight class will vary by year, and it is a '58-'62 engine. To find the exact year, the date code is cast on the passenger side of the block, at the rear next to where the starter mounts.
Bill Burmeister
LONGBOX55 #681668 09/29/2010 4:09 PM
longbox55 I removed starter casting # on block. CON 3 G39
can you tell me what year the motor is?
Is there a internet site where I can look the casting #s up next time?
I thought it was a 1957 motor but parts I got don't fit.
thank you for your help. Bill
55 GMC #681673 09/29/2010 4:35 PM
It's a '59. G=July, 3= the day of the month, 9= the year ('59)
waldo53 #681758 09/29/2010 10:39 PM
-Tom
1950 Chevy 3100 w/ 1956 235
Oilrag #681779 09/29/2010 11:41 PM
A thank you to all for the information and help finding out the year of this motor. Bill wave
