5 members (TUTS 59, 32Fordpuchoptop, ‘37ChevyPU, Barney1951, Cosmo), 118 guests, and 2 robots.
Topics128,050
Posts1,055,674
#681708 09/29/2010 6:50 PM
I haven't been able to find a breakdown of the steering box to be able to get a seal or whatever seals the pitman shaft this thing drools oil out pretty regular and the pickup seals don't seem to be the same or is it just a felt that is there, a moly ep greese is coming if I can't find anything, anyone know what it is.
ABento #681748 09/29/2010 9:37 PM
That's a pretty long sentence. You might want to break in down into distinct statements and questions.
3B Offline
Hy ABento, could you tell us what year of truck you are asking about please?
3B #681915 09/30/2010 5:24 AM
I didn't realize that we need to worry about correct grammer and such here.
Sorry its a 53 6500 not 6400,looks to be a felt or fiber type seal but can't find a listing.
ABento #681968 09/30/2010 1:52 PM
No need to worry about the grammar if you don't care to.
I think Tim's intention was a helpful suggestion that if you do take the time to type post that are easy to read you'll get more and better answers.
Personally I often just skim, or skip over all together, difficult to read post.
In the past I've replaced the felt steering box shaft seal with a couple rubber o-rings, and followed them with the original steel retainer. This was on a farm tractor steering gear box, but same idea and it worked great.
There are a number of threads on the proper oil/grease to use that both does the job of lubricating, but is less likely to run out. Plain old grease from a tube is not the answer.
Penrite steering box lube is one of the suggested solutions.
http://www.penriteoil.com.au/pis_pdfs/Steering%20Box%20Lube%20JAN%202010.pdf
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #682009 09/30/2010 4:05 PM
I've used Penrite in the White boxes and it still seeps, they have no felt just a bushing fit, the shaft on this one isn't loose or worn just that the oil works by it, I may try the JD corn greese and see what that does.
