| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | Got a Chevrolet motor 235 I think? Year unknown? Motor is a transplant into a 1941 chevrolet ton & 1/2 dump truck. Says Chevrolet on blue valve cover 2 screws on each side hold it on, oil cap on top of cover head casting #3835913 driver side of head. On the pass. side of head B26 913 241 570 In liners list head casting #3835913 as 1954 1955, 235 head--original head I don't know? Plate behind distributor F706J number.cannot find the distributor plate casting # listed? Cannot find block casting # anywhere on block ? Need correct year of motor so I can buy parts. thanks Bill
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The serial number comes out as Flint plant, built on June 7th, and the original application was truck w/manual trans, weight class will vary by year, and it is a '58-'62 engine. To find the exact year, the date code is cast on the passenger side of the block, at the rear next to where the starter mounts.
Bill Burmeister | | | | | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | longbox55 I removed starter casting # on block. CON 3 G39 can you tell me what year the motor is?
Is there a internet site where I can look the casting #s up next time?
I thought it was a 1957 motor but parts I got don't fit.
thank you for your help. Bill | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | It's a '59. G=July, 3= the day of the month, 9= the year ('59) | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 |
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | A thank you to all for the information and help finding out the year of this motor. Bill  | | |
