3 members (DoubleB, Chip O, JW51),
173
Mod | | | Forums66 Topics128,077 Posts1,056,016 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | guys, i just took my rear leafs off my 57 this week, but cant remember if the front leaf eye's get the thin rubber grease seals like the rear shackles do.... please set me straight. thanks
leonard | | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | No the rear shackles are the only eyes that have that rubber seal. The front eye just has the eye pin and the retaining pin | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | thanks for the clear up gumbi.
leonard | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I don’t see why the ’57 would be any different than the AD’s, the shackle is the same design. The illustration of the front shackle in the ’56 resto-pack shows a washer in place. Anyway, all of them that I’ve seen do use a dust seal in the front. The parts book is a little vague and it is not always 100% correct so I wouldn’t take that as gospel anymore than I would what is printed in a vendors catalog. In the end you need to apply a little logic, ie., does it make sense to seal water and dirt out of the pivot lubrication. http://www.pbase.com/dennygraham/image/122019804 http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0585.htm Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | No the 57's are the second series truck, some things on the chasis are different. On the AD's the leaf springs mount directly underneath the frame rails, so the shackle mounts are a different style. On the 57's the leaf springs mount on the outside of the frame rails. On the front eyes of the rear leafs its just a pin, not a bolt. There isnt any place to put a rubber seal. only the rear eyes use the rubber seals on the shackles. http://www.lmctruck.com/icatalog/ca/full.aspx?Page=84 ok dont know how to do a hyperlink but lmc's catalogue shows a pretty good picture | | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | ok so the hyperlink does work. cool | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | thanks again guys. got the leafs installed today. and no rubber grease seals for the front mounts (rear leafs). there aint no room for them, just the holding pin and lock pin.
when i get it all lowered i will post pics. i flipped the rear on the leafs and got me another 2 inches... gonna look cool.
after i finish the rear, then i gotta mess with the front leafs.
leonard | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | No the 57's are the second series truck, some things on the chasis are different. On the AD's the leaf springs mount directly underneath the frame rails, so the shackle mounts are a different style. On the 57's the leaf springs mount on the outside of the frame rails. On the front eyes of the rear leafs its just a pin, not a bolt. There isnt any place to put a rubber seal. only the rear eyes use the rubber seals on the shackles. http://www.lmctruck.com/icatalog/ca/full.aspx?Page=84 ok dont know how to do a hyperlink but lmc's catalogue shows a pretty good picture Nothin' but the facts, we need more of that around here.  | | |
