1 members (Hotrod Lincoln), 57 guests, and 1 robot.
Topics128,094
Posts1,056,066
Members48,433
#680641 09/26/2010 1:50 PM
guys,
i just took my rear leafs off my 57 this week, but cant remember if the front leaf eye's get the thin rubber grease seals like the rear shackles do....
please set me straight.
thanks
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
No the rear shackles are the only eyes that have that rubber seal. The front eye just has the eye pin and the retaining pin
thanks for the clear up gumbi.
leonard
I don’t see why the ’57 would be any different than the AD’s, the shackle is the same design. The illustration of the front shackle in the ’56 resto-pack shows a washer in place. Anyway, all of them that I’ve seen do use a dust seal in the front. The parts book is a little vague and it is not always 100% correct so I wouldn’t take that as gospel anymore than I would what is printed in a vendors catalog. In the end you need to apply a little logic, ie., does it make sense to seal water and dirt out of the pivot lubrication.
http://www.pbase.com/dennygraham/image/122019804
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0585.htm
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
No the 57's are the second series truck, some things on the chasis are different. On the AD's the leaf springs mount directly underneath the frame rails, so the shackle mounts are a different style. On the 57's the leaf springs mount on the outside of the frame rails. On the front eyes of the rear leafs its just a pin, not a bolt. There isnt any place to put a rubber seal. only the rear eyes use the rubber seals on the shackles.
http://www.lmctruck.com/icatalog/ca/full.aspx?Page=84
ok dont know how to do a hyperlink but lmc's catalogue shows a pretty good picture
ok so the hyperlink does work. cool
thanks again guys.
got the leafs installed today. and no rubber grease seals for the front mounts (rear leafs). there aint no room for them, just the holding pin and lock pin.
when i get it all lowered i will post pics. i flipped the rear on the leafs and got me another 2 inches... gonna look cool.
after i finish the rear, then i gotta mess with the front leafs.
leonard
Nothin' but the facts, we need more of that around here. thumbs_up
