7 members (greenie-reddy, klhansen, carbking, Mike B, Hotrod Lincoln, cmayna, Woodcmiami),
60
Mod | | | Forums66 Topics128,030 Posts1,055,421 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 50 | I have recently obtained this truck--as far as I can tell it is still all stock--The exhaust pipes are all rusted out. The truck has the original 283 engine. I want to keep it as stock as reasonable. The rams horn manifolds are good. Should I be looking for original exhaust pipes or some alternative? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | not likely to find original pipes unless you stumble on some NOS someplace, but if you check around older muffler/exhaust shops someone may have the spec card for bending them up - the crossover pipe will be the hard part, but a good exhaust shop should be able to make one up .... other wise any shop could make up the needed pipes for duals, which wasn't the original way, but works and sounds nice w/ a 283
Bill | | |
