| | | Forums66 Topics128,081 Posts1,055,959 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Back in the day we only used wool pads on our polishers. Today I see a lot of foam pads offered. Can someone tell me more about foam vs wool buffing pads?
Also, I need to get an electric polisher but my budget is under $100. Any suggestions on what to buy. I'm only going to use it to polish one truck. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | not into polishing much so I followed a body guys lead and got a foam pad to fit the angle grinder, cheapest choice for occasional use for compounding, and cheaper is likely the main reason foam is more common now, but my understanding is foam is easier to control and avoid swirls, wool is more aggressive
Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I would caution you to buy a low speed polisher. A high speed grinder will be much more likely to burn through. When I was in B&F trade school back when dirt was young the instructor drummed it into us pretty hard to NEVER use a grinder for polishing since they turn too fast. Now if you have a combo grinder/polisher with two speeds...........
| | | | | Joined: Jul 2005 Posts: 169 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 169 | Foam is gonna be less aggressive then wool and will take longer.
| | | | | Joined: May 2005 Posts: 281 'Bolter | | 'Bolter Joined: May 2005 Posts: 281 | Woody, there are two polishers listed on CL (Raleigh) might be worth checking out. | | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | I use both pads. Wool to take out the rough stuff and foam for for polishing. Learned this making surf boards. Brett | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | I use both, the wool tends to leave more swirl marks compared to the foam. One good way is start with wool and finish with foam. | | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | I recently purchase a polisher from Harbor Freight. It has like 10 speeds I think. About what speed should the polishing be done on? 3000 RPM? It is new paint.
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I would go less on fresh paint. 3K is pretty aggressive. If it goes as low as 600 I would start there. I wouldn't go faster than 1 to 1.5K at the fastest on fresh paint.
| | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | That makes sense. Last I polished I was using a polisher/sander. It had one speed of 4000+ RPM, It made the paint look dull. So I may need to repaint the cab, but I went out and bought this new polisher so I had the correct tool for the job now. I will try on the slower speed and see if I can get a better shine.
