2 members (Uncles51, Lostbuthaulinass), 79 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#67976 10/30/2006 4:20 AM
Apprentice
Apprentice
Hi Guys
i have recently rebuilt my rochseter B carb and now i am trying to set the proper timing on my 216. i am setting my timing as per the manula of 5 degrees before TDC. One i crank the engine to 5 degrees before TDC i set the distributor right before firing the first cylinder. I hope that is correct. for my next problem after i put my distributor in all the way and i tighten it up and i try t start the car the distributor jumps 180 degrees.
CHaimv
#67977 10/30/2006 4:49 AM
It may not have been all the way into the oil pump when you installed it. You can't time it when it isn't installed.
#67978 10/30/2006 5:20 AM
When you install the dist, look down the hole and use your 15" screwdriver to rotate the oil pump drive .
Allow for the dist to rotate as it meshes with the drive gear before it slides into the oil pump tang.
#67979 10/30/2006 5:36 PM
before you put dist. in you want engine at 0 degrees, or top dead center. as stated above you can't time it without dist in. and if dist. jumps your not getting it in all the way..using screwdriver, turn the pump where you want it, then when you put dist. in, start it a with the tang a bit to the left, so when it hits the gear it will turn a bit,line up and drop all the way in..
