6 members (1955 1 Series, walter74, artinva, Wally / Montana, SNOYL, Hotrod Lincoln), 59 guests, and 1 robot.
Topics128,078
Posts1,055,936
Members48,430
#679730 09/22/2010 5:09 PM
I have a 48 two ton chevy with what i was told was a mid 50's straight 6. was wondering if there is a "more modern" straight 6 that would be a "bolt in" replacement that will have better oiling and a spin on filter. Thanks!
Depends on which mid-50s straight six you have. What are the casting codes and the serial number on the engine?
Here are locations of codes on some low-pressure engines.
Here are locations of codes on some high-pressure engines.
Follow up on Tim's question first.
But the simplest "bolt in" swap and the most bang for the buck in my opinion will be a 261. They are "more modern" than what your truck originally came with, but not a "modern" engine.
a close second choice would be a 235 with full oil pressure, likely you'll find you already have one.
Either engine can be adapted to full flow oil filtration (if not already) and use a spin on oil filter if you desire.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
How do you adapt it to full oil filtration or how do I know if it already is? And what did the 261 come in? Thanks!
There is a Tech Tip on converting/adapting to full-flow oil filtration.
1958-1963 USA 261 engines had full-flow oil filtration from the factory. If the oil line holes in the block are 1/2" NPT, it has full-flow filtration.
261s were usually available in large trucks, depending on the year (1.5-2 ton trucks, usually).
