| | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 14 New Guy | | New Guy Joined: May 2010 Posts: 14 | I have a 48 two ton chevy with what i was told was a mid 50's straight 6. was wondering if there is a "more modern" straight 6 that would be a "bolt in" replacement that will have better oiling and a spin on filter. Thanks! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Follow up on Tim's question first.
But the simplest "bolt in" swap and the most bang for the buck in my opinion will be a 261. They are "more modern" than what your truck originally came with, but not a "modern" engine.
a close second choice would be a 235 with full oil pressure, likely you'll find you already have one.
Either engine can be adapted to full flow oil filtration (if not already) and use a spin on oil filter if you desire.
Grigg | | | | | Joined: May 2010 Posts: 14 New Guy | | New Guy Joined: May 2010 Posts: 14 | How do you adapt it to full oil filtration or how do I know if it already is? And what did the 261 come in? Thanks! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There is a Tech Tip on converting/adapting to full-flow oil filtration.
1958-1963 USA 261 engines had full-flow oil filtration from the factory. If the oil line holes in the block are 1/2" NPT, it has full-flow filtration.
261s were usually available in large trucks, depending on the year (1.5-2 ton trucks, usually).
