1 members (Gray_Ghost),
79
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | OK guys, need your quick help on this one. Got a exhaust stud broken off in a '67 pontiac exhaust manifold. Stud is broken off flush on the collector side, about 1/4" sticking out the top of the flange, flange is about 3/4" thick. Tried heating flange up and using vicegrips, but the nub turned about 1 full turn and stopped. How can I get this out? Got the manny off and with me here at work, Im gonna stay late and use the machine shop tools here. How do I get this out?
thanks
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
| | | | | Joined: Sep 2001 Posts: 2 Junior Member | | Junior Member Joined: Sep 2001 Posts: 2 | Other than heat, liquid wrench, candle wax,(search other posts) working it slowly in and out...... If you've got a complete machine shop, you could attempt to drill it out, last resort. When you do get it out, and put that new stud in there, and reassemble your exhaust system, put BRASS NUTS ON THE STUDS they won't interact with studs and do that rust weld thing. | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Chiphead: Since you got it at the shop do this, drill center pilot hole use your easy out, make sure it good and tight, then apply heat to broken stud. Take your time don't rush,done many this way and they finally back out. Remember your working with heat and easy out, patience is the factor. popcorn | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Chiphead: Since you got it at the shop do this, drill center pilot hole use your easy out, make sure it good and tight, then apply heat to broken stud. Take your time don't rush,done many this way and they finally back out. Remember your working with heat and easy out, patience is the factor. popcorn
The Truth Is Out There | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Patience, patience and more patience, as well as what these guys mentioned. You got it to move once, that is a good start.Use the wax trick and you should be able to remove the broken part,,,,patience
| | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Kranoil works wonders in this type of application. Soak it good and let it work. | | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Well, I gimped up the threads above the flange due to the vice grips. So do I grind the top flush with the flange and try to drill/EZ out, or do I try to unscrew it out the top? I was thinking about MIG-ing a nut or something to the nub sticking out the top and trying to unscrew it out the top. Will that work? And whats with the candle wax? The machinists already think I'm off, what if they see me with the candles and Kroil massage oil? chip
| | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Chip: Find out about wax been in the shop about 35 yrs. aint to old to learn. Ok to grind flush, drill, then easy out, or weld nut to nub. still need heat to eaze out. As I tell my boys patience my son. Worse come to worse drill out total and then heli-coil another bolt in. I keep a hospital running. Wax I'll be damned. popcorn
The Truth is Out There | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | WARNING about using an EZ-out on the exhaust pipe to manifold bolts:
I cracked my flange when using an easyout. Yes, the flange cracked, the bolt still did not come out, and my Harbor Freight "EZ out" drill did not break. As popcorn3023 has already suggested, you still need heat to free up many of these stuck bolts.
I suggest you try the other heat and/or wax/solvent-based techniques (or both) suggested above.
Tim | | | | | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | A trick we picked up to get rusted frozen machine screws out of oven burners was a few drops of liquid soap, ivory, joy, etc. Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
| | | | | Joined: Jan 2003 Posts: 8 Member | | Member Joined: Jan 2003 Posts: 8 | Chiphead, This is not a commercial, but I continually amazed by the ability of "PB Blaster" to break loose rusted bolts/nuts. I would try to describe it, but I think it would be easier to just give you a link to their website. It used to be sold only at auto parts stores, but now I see they have it Wally-World (Wal-Mart). PB Blaster Web Link | | | | | Joined: Feb 2001 Posts: 3 New Guy | | New Guy Joined: Feb 2001 Posts: 3 | Put a washer over the stud, weld washer to stud. Now weld a nut to the washer, heat up the manifold again and remove
38 Chevy 1/2 ton
| | | | | Joined: May 2001 Posts: 46 Member | | Member Joined: May 2001 Posts: 46 | The machinists already think I'm off, what if they see me with the candles and Kroil massage oil? LOL, Iv'e used this trick at work several times (and yes,they know for a fact I'm a little off  )But it works!  Apply heat to one side while applying the wax to the other.It makes a mess but the wax will be drawn towards the heat. | | | | | Joined: Dec 2000 Posts: 64 Member | | Member Joined: Dec 2000 Posts: 64 | I'm with hseber about welding a washer and then the nut to the washer. When you do the heating get the flange a light red hot then take a water hose and cool it fast till it is cool to the touch, take a wrench and turn the nut, it should screw out pretty easy. The secret to it all is cooling it fast.
kdot em3
| | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | ChipHead: DID you get the bolt out the suspense is killing all of us. Thought that would be the first thing I would read this morning!! Of course we need to know what trick you used. Wax I'll be damned. popcorn
The Truth Is Out There. | | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Well, I thought I was going to have to do this myself, but as I was setting it up in the shop last night, Stuart (stu-daddy) the toolmaker volunteered to remove it for me. He drilled about a 1/8" hole thru the center of the stud to stress relieve it, and now its soaking in Kroil he brought from his house this morning. Don't know exactly what he's got planned for the removal. I'll let y'all know.
chip
#6803 03/14/2003 10:49 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Mabey one of those lazer knife things they use to remove cancer
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Drilling a hole completely through it works well with the welding technique, it gives the outer diameter some give to work over the rough spots on the rusted threads.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Do those rounded bolt removers like I saw at Sears ever work? They fit over the top of a bolt, gouge into it when turning and remove it, in theory. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
