0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | I have a 47 1.5 ton. The original gearbox was filled with water running down the dash and dripping down the gearlever. I got another one just the same. Both are definitely SM420, 4 speed: box #1 590474, date code j62 box #2 5834141, date code 11 67 Both boxes are full 4-speed crash. There is no synchro cones at all. It looks to me like they never had any. They both work fine but the teeth do the meshing.
Has anyone ever heard of SM420s with no synchro? Maybe we never got synchro boxes here in NZ.
'47 Canadian RHD 1.5 ton truck
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | In '47 the SM420 would not have been stock, the first year for the SM420 was '48. Do these transmissions have a release lever to allow getting into reverse?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Do you have the transmissions apart? The synchros in SM420s are not near as visible as they are in a Borg Warner transmission. If they are indeed 420, there has to be something that would take up the space of the synchros. | | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | Good point. I was expecting to see the usual large synchros I'm used to in modern boxes. I will download a manual and have a look. I have had the top off and there is nothing to stop the gears sliding together. They slide effortlessly up and down the shaft until the teeth engage.
Oldsub- neither box is original, according to what I think are the date codes. What came before the SM420? Something with identical dimensions that would bolt in where an SM420 appears to fit now? both my boxes have the pull up lever for reverse.
Thanks for your responses.
| | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | I downloaded a manual. I must have some old pre SM420 box? They look identical externally but there is definitely no synchro, also all my gears are straight cut, the SM420 manual shows synchro cones and helical cut gears. Too bad, it will get it moving and stop my wife wanting to drive it.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've never heard it called anything but a crash box. I'm sure the early transmission has a name or designation but I don't know what it is.
The release lever confirms you don't have an SM420.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | ...What came before the SM420? ... both my boxes have the pull up lever for reverse. That answers the question, having the little thumb lever for reverse indicates you don't have an SM420, but rather you do have the non syncro predecessor. Grigg | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Back in the 50's we referred to the old one as the "GM sliding gear 4 speed" and the newer one as the "GM synchro or SM420". They do not bolt to the same clutch housing. | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | Is that the reason why you have to double clutch? | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Double clutching is to synchronize sliding gear transmissions. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | "GM sliding gear 4 speed" I'll try to remember that. Back in the fifties I didn't know what a transmission was...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | I cant explain the 60's date codes on the castings. Too bad.
This may bring on a repower and new trans a bit faster.
