5 members (Gdads51, Otto Skorzeny, MickeyP, dt235sd, JW51), 62 guests, and 1 robot.
Topics128,049
Posts1,055,698
I have an extra driver's side door that does not have the wind wing window. So is that door for model years 1947 to 53?
I'm just not sure when the first year for wind wing windows was.
I will be listing the door for sale on ebay and want to list the correct years.
thanks,
47-50 assuming it is not just a door with a missing vent window. Does it have the full glass in it?
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
No glass. and no place for a vent window.
So is that 47 to 50 then? 51 up had a vent wing?
Some pictures would help us help you but yes it is likely a 47-50 door. It is also possible it could be 51-54 in that the vent window assembly can be removed from the door. Check for modifications to the metal work along the top near where the back of the vent window would go. The vent window doors were pinched down to meet the vent window assembly in that area. Another indicator is the window regulator, 47-50 had a scissors type arrangement and the newer doors had a single arm type regulator.
1953 Chevrolet 3600
ok, pics later, thanks
Push button door handles were '52 to '55 1st. You need to look harder for evidence the wing window was removed.
good call on the handles. I forgot to check that, too.
Scot,
If you look at how the fastener holes and where the rubber stops it had wing glass and was robbed.Also good info that with the wing glass removed the inner front channel is in there and can be used without for a 47-49 truck but you would have to get different regulators door handles and interior ring.
Sully
