3 members (sron48, Otto Skorzeny, 1 invisible), 89 guests, and 1 robot.
Topics128,154
Posts1,056,856
Members48,456
When I pulled the engine the other day, I left the tranny on because I couldn't get it disconnected.. I just removed pretty much everything from the engine (carb, maniford, starter, etc) and all I really have left to remove now is the tranny... How the crap does the transmission unbolt from the engine? I see 2 bolts at the top of the transmission connecting to the engine, but it looks like its 1 solid piece.. but I know it's not! Frustrating! How many bolts connect the tranny to the engine.. where are they????? smile
1952 Chevy 5 Window Restoration
The other 2 bolst are inside the bellhousing. You'll have to remove the sheetmetal cover from the bottom of the bellhousing to get to them. The remaining 4 bolts that attach the bellhousing to the block are accessed the same way, after the clutch and flywheel are removed.
Bill Burmeister
pull the transmission from the bellhousing first....then pull pressure plate, clutch, and flywheel...then pull bellhousing from engine...
This is a pain.. the way I have it, its hard to get to the bottom of the bellhousing to get to the bolts for the tranny... I still have it hanging from the hoist with a chain wrapped around it. I need to get all of this removed and get that engine put over onto my engine stand...
Well, the chain is wrapped around it, but it's sitting on a wood pallet thing....
Roll it on its side and proceed. Remove the distributor and fuel pump first if you lay it on that side.
