| | | Forums66 Topics128,093 Posts1,056,046 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 32 Member | | Member Joined: Jul 2001 Posts: 32 | [img]C:\WINDOWS.000\Desktop\MVC-003F.JPG[/img] I dont know if this picture posting is going to work but if it does. The one on the right is my stock 4sp. Transmission and the one on the left is my saginaw. Can you see the difference in bolt holes? because the bottom left one on the saginaw doesnt line up to the bellhousing. Thanks, Mike | | | | | Joined: Jun 2000 Posts: 738 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 738 | Mike send me the pictures and I will post for you. So you can get an answer to your question!!  | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Don't know what you've got here, but I was thinking the later sag car trans would go right into old trucks till 67 or so and then they had bigger bearing housing on front. The bolt pattern stayed the same tho. Sure you got a sag for Chev? Maybe they made some x-ler or others? Wouldn't think any GM would have diff pattern either. Any thought on redrilling for new ear? Have heard of some doing this, sounds hard to me! PS, some old F-trucks had b/house with a narrow gap for bolt on right side, is that what you have? Their housings had the narrow and the wide spacing depending on what trans went in truck.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Jul 2001 Posts: 32 Member | | Member Joined: Jul 2001 Posts: 32 | yes, im sure its a saginaw from a chevy. I thought of drilling the ear. but dont know if i would want to do that or not.Thanks, Mike | | | | | Joined: Jun 2000 Posts: 738 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 738 | | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Hard to believe there's a difference. Still think it's for a diff brand! :p Not F*** as not narrow enough. AMC? Was wondering if that rope was on it to keep it from running away?  :p
| | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | I just noticed after looking again that the bearing retainer (part for t-out bearing to slide on) looks much bigger on sag than 4spd and it won't go into your orig b/house by anout the 3/8" of it's thickness. Did you find that a problem? Chevy went to bigger hole in bellhouse after 68 and these trans' won't fit earlier b/house. I was thinking the cars carried on the smaller one and if used from car will still work in old truck b/house. Is this trans from a truck? Didn't think they had small 4spd in trucks, how to shift? Think you need older trans to work for you. Lots of the cheap basic cars of 70's and 80's have these in them.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Its NOT a GM box thats for sure. My bet is also AMC or mopar. It dont even look like a sag to me were the counter shaft goes in.. It dont matter as GL says it wont work anyway time to get rid of it and get the right box.Show a side view and we will tell you what its for. No #'s on the box..One thing for sure you got more than just a bolt problem. | | | | | Joined: Jul 2001 Posts: 32 Member | | Member Joined: Jul 2001 Posts: 32 | Thanks for the information. The Transmission is from a 68 camaro. I will get the number off the side tonight. Mike | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | | | | | | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | Maybe its just me but if u put a rope on Tony's it could pass for Buck's.
Buzz'n Half Dozen
| | | | | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | hello buckonine, what truck did the older tranny come from? year? it looks like the one in my 48 gmc 3/4 ton. good luck.
our garage is a non-profit organization
| | | | | Joined: Jul 2001 Posts: 32 Member | | Member Joined: Jul 2001 Posts: 32 | My transmission is from a 48 GMC 3/4 ton . That true saginaw looks idenical to mine. Thanks for all the information, Mike | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | I had a pile of Saginaw trannys.Some from the 70's. Everyone had the same diameter front bearing retainer, about 4-1/4 inches. Same as the hole in the older truck bellhousings,which are supposed to be the same from 48 on up.The bigger hole in the bellhousing applies to 68 and newer 4 spd trucks.I believe the trucks with 3 spd Saginaws still have the smaller opening.Looks like Bucks bellhousing may be the problem here.Perhaps GMC's are different, but a 235 housing will bolt up. | | |
