3 members (KEVINSKI, dt235sd, Bill Hanlon), 109 guests, and 2 robots.
Topics128,049
Posts1,055,675
#674583 09/01/2010 3:19 AM
About 40 years ago, we put a 55 chevy truck straight axle under my 57 Chevy belair. I want to think we used 53/54 Chevy car front hubs, bearings, and brake drums on the truck spindles, to convert it over to 5 bolt pattern. It been too many years and too many
beers ago to remember for sure smile. Would anybody know for sure? I want to convert my 55 3100 over to a 5 bolt pattern.
TIA. Brian
Brian
1955.2 3100 Truck
the beer hasn't kicked in yet wink the earlier car hubs do fit the trucks
I did it back in the 70's. Put 53 drums on all my PUs 55 thru 57. Just need to use the pickup inner bearing and race because the car spindle is different on the inside. Also you need to loose the dust shield.
Larry
58 gmc 100 with 350 sbc
I did it back in the 70's. Put 53 drums on all my PUs 55 thru 57. Just need to use the pickup inner bearing and race because the car spindle is different on the inside. Also you need to loose the dust shield. It worked back then even when stupid enough to run them over 100 mph. I made it through those years thank goodness.
Larry
I'll join the crowd. I also did this swap in the 70's on a '41 Chevy 1/2-ton. I had to make new spacers between the backing plate and spindle, but that was no big deal.
OK, Im in too. It musta been a '70s thing.
I used '53 car hubs and drums on my '54 truck axle so i could run my "cool" tru-spokes. Iv since thrown away the tru's, and still have the 5 lug hubs and drums....around here...somewhere.
If you want to sell them please let me know.
[email protected] Thanks, Jeff
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
i open drive the and added 54 car hubs drums in the front to run 5 lug 14 inch wheels with 5.20x14 tires with crossbar wheel covers it was in the late 70s now i just go straight to disc brakes
1949 SUBURBAN
