0 members (), 192 guests, and 0 robots.
Topics128,089
Posts1,056,143
Members48,436
#678880 09/19/2010 4:14 PM
Hey All, looking to replace my spilt rims on my 53, having a hard time finding a wheel that will fit. any help out there.
Thanks Cardo
I went to Les Schwab on Friday. No problem. Ask for rims for a 1969 Ford F250. Those will be 8 lug 1/2" stud. You will need a wheel spacer if you do this unless you use the modern tie rod setup I am working on. They had 4 on the shelf. Should be about a 16" x 7" rim.
My brother did this back in 1995. I was just looking to maybe replace the rims again since they rusted from the truck sitting again.
Thanks Cardo
Read through this thread. I was in the same boat as you. All set and done it cost me about $300 for the new wheels and the tierod + ends. While there are probably much cheaper options available, the rims look darn near stock and work great.
