3 members (55shaker, Otto Skorzeny, GMCJammer51), 97 guests, and 0 robots.
Topics128,050
Posts1,055,646
#678734 09/19/2010 1:00 AM
My new radiator cap on my 46 COE is very rusty inside. What can I do to stop the rust? Should I not be useing antifreze?
You should always run antifreeze. You can flush cooling system to remove rust but in these old trucks you may never get rid of it all. Could be coming from heater core also.
1952 Chevy 3100
More pictures in Photobucket
Doin better'n some an worse than others. Life's what ya make of it. FAMILY, GOD and COUNTRY. Love it or Leave it.
What is the pressure setting of your radiator cap?
A variety pf types of "anti-freezing" solutions were used in 1946 (methanol, denatured alcohol, ethylene glycol, and glycerine) and some of them were corrosive. Are you using any type of anti-freeze? Straight water would be more corrosive than a modern anti-freeze (which have anti-corrosive compounds added).
It is very hard to remove rust and sediments from an installed engine/block. Drain and flush the system as suggested by Old Dollar. Then add a modern anti-freeze (usually 50-50 with water). I try to find anti-freeze that does not contain silicates (it also is usually less expensive).
Chris, are you using a cap from the vendors? If so, they are junk, made in China. They have steel rather than brass on the under side. If you are using one of these go to a auto parts store and purchase one to suit your radiator. I have been there, done that.
The presure on my cap is 0 like original. I'm useing 50% antifrezze. My engine was totaly boiled out and cleaned My radiator cap is NOS. It's like the steam is rusting the bottom of the cap, fluid never touches it.
Mine did the same... I cleaned it up and painted the bottom side with Rustoleum though even that doesn't last forever, but is a low dollar remedy.
1946 Chevrolet 1/2-ton
More pix on Photobucket
