3 members (F100Ranger, Bill Hanlon, latroca52), 147 guests, and 2 robots.
Topics128,192
Posts1,057,350
Members48,469
#677762 09/15/2010 3:58 AM
What is the metal thickness for the 1955-1959 2nd series trucks? I've seen 18 guage and 20 guage. I woulg like to knoe because I have to reconstruct all of the sheet metal around the windshield area (don't know how yet) and I need to buy some sheet metal. Any recommendation on what sheet metal to buy?
Most exterior sheet metal was 19ga or about .042
18 ga is around .048
19 ga is hard to find many suppliers simply dont carry it.
If you go to a metal supply store ask to mic the sheet as tolerances can be all over the place. You might run into a piece of 18 ga that is pretty close to 19 ga in thickness.
Very rarely will you find sheet metal on the high end of the tolerance, I would try to buy 19 but 18 if not found...Eric
Currently working on custom metal and How to videos.
1949 and 1972 chevy trucks
70 chevelle SS455
Pictures of my work and projects
http://community.webshots.com/user/sevt_chevelle
Thanks. I saw on Ecklers that a lot of their parts are 19 guage. Is there a certain type of sheet metal to use? I know I can't use galvanized for obvious reasons. I still have to find a supplier in my area.
If you have an industrial sheet metal shop or fab shop in your area, they probably sell small pieces of 18 gage sheet that you could use for these parts you need to make.
By the way, 19 gage steel thickness is 1 millimeter. American suppliers typically use 18 or 20 gage. 19 gage is probably more common in parts coming from other countries that are on the metric standard.
Mar-Ktech
Thanks! I'll check that out.
