3 members (Gdads51, Ol'55, Otto Skorzeny), 101 guests, and 2 robots.
Topics128,049
Posts1,055,649
#67840 10/26/2006 8:15 PM
Ever since doing a T-5 swap in my '52 there has been an almost constant grinding/rubbing noise that speeds up and slows down with the truck. It is there with the clutch pedal pressed in and let out. The transmission shifts/drives fine and there were no metal flakes in the fluid when I changed it. The driveshaft was cut and balanced. What could this be?
Some things that I am thinking... input shaft bearing is bad, TO bearing is adjusted to rest on the fingers, TO fork ends should be round (welded flat because I thought this was wear), or the rear U-joint needs to be greased (I packed it when I put it back on but never shot it on the zert)... any thoughts?
#67841 10/26/2006 10:27 PM
Riding in the Passing Lane
If it was the input shaft brg. you will hear it in neutral & it would go away when you put the clutch in. If it is any trans. brg. it will be much louder in all gears except 4th. I wouldn,t suspect a u-joint either. What about wheel brgs. How about diff. brgs. Did you change the rear end at the same time. The t.O. brg adjustment is easy to check & if it not contacting the clutch fingers it wouldn,t make any noise.
1972 Chevy c10 Cheyenne Super
#67842 10/27/2006 1:14 PM
The rearend is a F*rd 9" and was in there before the tranny swap and there were no problems with the differential or the wheel bearings. I will do some checking this weekend on the TO bearing but it sounds like this is probably the input shaft bearing.
#67843 10/27/2006 1:20 PM
Would wonder if you have contact between the tranny and a body part. I had to do some extra hammering once after making that change on another truck. Now I have a muncie and they all are noisy.
