8 members (Jay R, Gray_Ghost, WICruiser, Greg_H, Otto Skorzeny, Wheelie, 1955 1 Series, Napco Man),
149
Mod | | | Forums66 Topics128,083 Posts1,056,080 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | I want to replace the lower door hinge bracket because the captive nuts have come loose. I'd also like to replace the inner and outer door bottoms. I was wondering about the difficulty level of doing this and about the interior door structure. Is there any kid of framework inside the door so I can align and mount the panels? Thanks for the help! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | will take a moderate amount of metal working skill and a lot of patience - there's a 'structure' involved with the hinge mount in the door, but the shape and the pinch weld where the outer skin wraps the flange of the inner shell are the only lower 'framework' ... alignment is careful measurement and marking of the original as it's taken apart Bill | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | a moderate amount of a skill I lack! Sounds like a challenge! Good thing I have two passenger side doors to experiment on! | | |
