7 members (JW51, TUTS 59, 3800GUY, Otto Skorzeny, cmayna, 52GMC35424JD, 1 invisible),
105
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 66 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 66 | I tried the search option,but come up with posts about seats,etc.So here goes.... I have a '60 Apache C30 with no seat belts.What are my options?2 point,or 3- point? Where to drill mounting holes? I can't take our 5 year old Grand- daughter in the truck.
- Doug
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i installed a latter lap belt for my wife on the pass side. i used the seat brackets i made to save drilling any holes or running bolts thru cab. i'm sure shoulder belt is much better, but i don't know how other folks are doing that. good luck | | | | | Joined: Sep 2010 Posts: 24 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 24 | Not really sure if you want to change seats, but I have a 63 1/2 ton and i installed bucket seats from a 2003 Chevy truck. The seats have the retractable shoulder strap and the female end built into the seat. The seats I found were in excellent condition. The seller wanted 300 but I talked him down to 200. The seats fit really good but I had to make a bracket for the center portion of the seat because the hump is different. The center portion also has seat belts. I think the bench style seats in newer trucks are the same way. | | | | | Joined: Jul 2009 Posts: 5 New Guy | | New Guy Joined: Jul 2009 Posts: 5 | I installed 3 point lap and shoulder belts in my 65, aftermarket from; http://gemstreetrods.com/Seat%20Belts.htmThey were inexpensive and very easy to install. | | | | | Joined: Aug 2010 Posts: 66 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 66 | How did you anchor it?-Especially the shoulder belt anchor?
- Doug | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I'm using simple latch style lap belts. | | |
