| | | Forums66 Topics128,043 Posts1,055,609 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 66 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 66 | It looks like my air cleaner is leaking onto the carb.Is there a seal at the base of the air cleaner?What's the best way to fix this? I don't have an owner's manual,or a shop manual,so I'm learning. This is on a '60 C30 panel truck.
- Doug | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if your oil bath air cleaner is actually dripping oil, it's because there's a hole in it, OR it's overfilled, loose or all of the above, - a bit of oil film will usually develop over time, just means it's time to clean it up and replace the oil, they do require some maintainence
Bill | | |
