4 members (Robert Crandall, J Lucas, 1955 1 Series, Otto Skorzeny), 99 guests, and 2 robots.
Topics128,094
Posts1,056,465
Members48,443
#676380 09/07/2010 11:17 PM
1 Offline
Can I make the vac. advance line out of brake line ? Are the brakeline fittings the right threads? Thanks
Yep on the 3/16" steel brake line and yep at one end, the end that goes into the stock carb base is a compression fitting.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thought they were smaller than 3/16", or it is just because the 5/16" fuel line beside it makes the vacuum line look small?
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
1/8" for the mechanical "sender" line to the oil pressure gauge. (the vacuum-advance line has a larger diameter).
Could the vacuum advance line be 5/32" or is it truly 3/16" as Denny said it is?
I should go measure mine but won't be able to till Monday..
I only ask because looking at the picture in my mind I see 3/16" as being to large, and I have a fairly well calibrated eyeball...
Grigg
---All pictures---
Every one I can remember replacing was done by using regular 3/16" steel brake line. There's an oddball fitting on one end of some of them, the one-time use compression fitting with the tapered end that grips the steel line. Ford used a similar fitting on the ends of 1/4" fuel lines, IIRC.
-Tom
1950 Chevy 3100 w/ 1956 235
1 Offline
This is Elmer here; I bought the fittings that would go on the 3/16 brake line. The one that goes on the vac. advance fits right but the one that goes on the carb does not seem right, and I Don't want to force it to mayby strip the threads. They look right but if someone said they used the fitting from the brake line there I would try it. What do you think?? Thanks
Measured several at a truck show this weekend, 3/16" it is.
Sorry for the confusion and not being trusting.
Grigg
The end at the carb has a compression fitting (as Hotrod Lincoln stated above) on mine (Carter W1 carb). You can buy one at NAPA.
1946 Chevrolet 1/2-ton
More pix on Photobucket
1 Offline
Yeh; The compression fitting on the carb end makes sense now. Thanks for all the good feedback, I don't know what I would do without you guys. I'm sure I'll be calling on you again in the future so thanks again.
